elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun Feb 20, 2005 4:10 am
Meaux... I know exactly what your saying, but I really dont think its the TPS... Ive already gone screwed mine up (at least its close now, perfection comes later).... Reason i say this is Ive had no change when i swapped in a known good one... Hell, i took the TPS OFF THE CAR, set it to .44 volts as read by my VOM and it still idled funky....
Just so you konw, a dirty IAC tends to make the idle lower (!) because when its dirty, less air passes through.... So expect it to idle higher when you clean the IAC, and youll probably have to back in the screw all the way as well...
However I dont think its a vacuum leak because of what i decribed earlier.... Plus if it were that big you could probably easily trace it with a steth... I need to go have mine checked, but the shop is very busy.. One of my local independents (who did my suspension work on my first Q) has this nifty vacuum leak detector... Its this smoke machine (similar stuff to the smoke they make for stages and performances) and you hook a hose up to the brake booster port.... Then turn off all the lights and have a flourescent light in the engine bay, and smoke will come from wherever the vacuum leak is... I think its kinda nifty.....
If you want to read your TPS voltage, do this... Assuming you have a DVOM (with that many german cars, i hope you do ), get a straight pin, and on the TCU (sounds goofy i know, but if you look at the circuit diagram it makes sense.... TPS voltage goes to the TCU and the ECU)... Probe terminal 34 and 35.... Look in your FSM to see exactly where they are, i cant remember. Its in the foldout section, right under the ECU pin terminal locations.... If memory serves its the 2 pins on the top row, the last two pins closest to the dashboard (higher vs lower)... Me trying to describe it probably made you more confused so check your FSM... As always if you dont have one just email me and ill get you one....
By god we're going to defeat these damn cars and make them idle right!
