To catch up with the original mods on the first project car, within the first months after getting the car we reinstalled the following mods:SilviaS14KA24DE wrote:oh, mind you, if you read that article, they say CLOSE to 200. They never said removing the A/C will gain 50hp. Who cares what they said about trying to get 200. All they're doing is trying to get the most HP out of, well basically doing tid bits (well except the cams). I believe they can achieve close to 200 hp. However, they didn't list ECU programming, or upgrading. At least support them. If they don't get it, oh well, at least there will be a good power gain (obviously they'd make more than stock 155). If they do, I wouldn't call BS.
but then again, thats in my logical opinion.
Injen cold air intake Aluminum drive shaft TEIN Flex coilover with EDFC Nismo solid shifter Cusco Front and Rear OS strut bars Inner Circle ECU rom tuning Nology ignition hot wires 5 Zigen Border III 2.50" catback Sun Hyperground kit Fuel filter, oil and plug change Cap and Rotor change New O2 Sensor Catco 3" Highflow Cat Nismo Transmission mount swap Pressure wash engine bay Removal of dead mouse on a/c compressor (50+hp)
ummmmmm.............
