high comression DE swap is full on
Chingon
Car: 1991 and 1992 hatchbacks
damn it!!
dubstyles240
for real, its been so long
i got my old DE ripped apart in my basement, just waiting for 10.5:1 compression, 248/248 cams, and mayyyyyyybe a 75 shot for the official races ;)
corn322
Car: 1993 240sx
(jepordy music)
JonnyB4Real
jeopardy*
thekage
Car: 98 Dodge Caravan
98 Dodge Intrepid
bump
mackdaddy240
Car: High performance with a clean look.
Did you have the block machined? because theres a little wear in one cylinder wall but I didnt know if the old stock pistons would fit tight enough after having the block machined. Has anyone worked on the block before putting the pistons in??
driftaholic
Car: '91 Nissan RM S13
need results!i blew up my motor, so i'm getting another an am 90% gonna put sohc pistons in it.
dabum
yeah man i been waiting the first day the post came up!CHARTS! NE INFO! PROGRESSSS
mackdaddy240
OK man I dont even really care that much about the dyno, Im just curious about the 1/4 mile time, I know 240sx arent drag cars but its big around here and Im doing a H/C de swap in my 90 240 to so I was just wondering about what time I'll be running there are a lotta slow imports around here and the fastest NA import ran a 14.3 just curious if I could win some money at the track!!:D
chandler
Car: 91 civic hb & 96 S14
Id really like to see the air fuel ratios on the engine, and the dyno charts, hey any one make forged high comp pistons?
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
High compression N/A plus a lot of bolt on's will not get you into the low 14s with a 240SX.
2400lbs (very light 240SX) plus ~170rwhp may net you a mid-to-high 14, but no 14.3.
You'd lose money...hehe.
driftaholic
i started my motor swap on friday. almost ready to put the new motor in. i'll be using E pistons in a DE, but with 2 DE exhaust cams. injen intake and 5zigen proracer for now. more mods to come. i'll be sure and post up a dyno chart as soon as everything's running right.the swap
240convertedme41
You know i saw somewhere that an n/a ka24de altima was running a high 13.. so why couldnt a lighter 240sx do it?i like this forum much better less talk about that most dreaded srbull#$3 . I heard the same thing back in my honda days.. b16 this b16 that.. why not stick with the original.. ka24de all the way baby ;)
hudy
Car: 1991 240SX SE Hatch
How does the starter hold up to high compression? Is it powerful enough to spin the engine fast enough to let it start? Have you ever seen a diesel starter? They are very beefy. Then again they have like 20:1 CR
TrunkMonkey
Car: 2000 Lincoln Navigator
hudy wrote:How does the starter hold up to high compression? Is it powerful enough to spin the engine fast enough to let it start? Have you ever seen a diesel starter? They are very beefy. Then again they have like 20:1 CR
the size of the starter has nothing to do with the compression ratio. it's the size of the flywheel. have you ever seen a flywheel from a diesel engine? pick one up and you'll see why the starter is so big.
-demetrius
feint240
driftaholic wrote:i started my motor swap on friday. almost ready to put the new motor in. i'll be using E pistons in a DE, but with 2 DE exhaust cams. injen intake and 5zigen proracer for now. more mods to come. i'll be sure and post up a dyno chart as soon as everything's running right.the swap
yyeeaaa NCDA.NET REPRESENTING!! ...ok im done.
where is this silver guy...he hasnt posted in a while on here...:confused:
w1ngzer0
Car: Pfft. i don't own a box
hopfully i can stay awake long enough to order the head and other parts that go with it
feint240
i wish i could order some head...
lol
w1ngzer0
feint240 wrote:i wish i could order some head...
lol
but you can. You don't live to far from sacramento lots of nudies and lots of sluts.
Chingon
not highjacking...but where did you get brand new E pistons? how much?
mackdaddy240
http://www.importperformanceparts.net/I bought topline, I got pistons rings, and gasket set for about $350 I think. They were pretty fast too.
driftaholic
i got my pistons from devious
