If you do it right, it will turn out fine. I have 6000k HIDs in my prelude (non projector), and while they aren't as nice as my 6000k Miata (projector), they ARE nice.asoomal wrote:You need projectors.
Please don't try to install HID's in those housings.
Hmm, I can't seem to find any... here's a shot of the Prelude though. They look just a tiny bit blue when you look at them, but when you are behind them, its pretty much just white.asoomal wrote:Any pics of cut offs?
I'm checking out hidextra now. What's the difference between hi/lo kits and normal kits? Also I don't need a relay wire harness or anything like that do I? Definitely going with the 6000k now. Are yours in your prelude 55w or 35w?PapaSmurf2k3 wrote:If you do it right, it will turn out fine. I have 6000k HIDs in my prelude (non projector), and while they aren't as nice as my 6000k Miata (projector), they ARE nice.asoomal wrote:You need projectors.
http://www.hidextra.com is a NICO sponsor, and pretty much gets you anything and everything you need, for a good price.
I just ordered the 35w 6000k. Are these still going to be brighter than stock? How was the install?matt_240sx wrote:I have the kit on my 240. Works perfectly. I would recommend going 35w. No need to go 55w. You'll blow fuses from what I'm told.
Caveit, please do comment on the installation when you do it. I have a 96 as well and I will do this mod in the future.Caveit77777 wrote:I just ordered the 35w 6000k. Are these still going to be brighter than stock? How was the install?matt_240sx wrote:I have the kit on my 240. Works perfectly. I would recommend going 35w. No need to go 55w. You'll blow fuses from what I'm told.
The kit was plug and play for my Miata, but required some minor stuff for my Prelude. The prelude has a pretty funky headlight wiring setup, so I wasn't surprised. I basically just had to solder some male tab connectors onto the ends of their wires and plug them into my factory headlight wiring. Not a big deal at all.alms24sebring wrote:I wish I knew about HIDextra.com earlier. Is it all plug and play?
X2 it's just a shot gun blast all over the place vs real HID.asoomal wrote:You need projectors.
Those have a nice looking cut off and don't cost a crap load.1SickSilvia wrote:After reading some of the post i say some of the info is correct but I would highly recomend retrofitting your head light with projectors. Without projectors you wont get the full efficiency amd output of hid bulbs you will glare oncoming traffic and get flashed alot. Please check out this site it has a forum to get the info you need http://www.hidplanet.com
I would go with this set up
-Morimoto mini D2S or H1 projectors
-35w ballast
-philips hid 4300 or 5000k bulbs
