I love the look of seeing tho.audtatious wrote:Yes I'm aware. I don't like the "yellow" look of the factory 4300's.
seen your sig but not getting what point there is. A projector setup will outperform a free form setup 9-1 . There are very few reflector setups that come close.audtatious wrote:Did you not see my sig above nor what I list as my cars under my username? I have a 2k2 Maxima AND a 2k8 G37 coupe. The Maxima has D2R and the G37 has D2S.
Maybe, maybe not. I drive both cars. Both cars have HID setups. One is reflector and the other is projector. I like the lighting from the reflector one better. Some of it is due to the cutoff of the projector being distracting when going down dark 2-lane roads.kzoosho wrote:
Depends on who you get the kit from and who makes the bulbs. If you get a high-end kit with Phillips-style bulbs you are looking to pay a premium. If that does not matter to you then you are probably looking in the $300 range for the two kits.BOBCAT wrote:How much would a HID Headlights and foglights MOD cost for my 2K? That is new headlights and all.
Upgrade to 2k2 lights. Sure, you will have a small gap but it is far easier.BOBCAT wrote:Not to bad. About to put my suspention on tomorrow. I cant wait. That means i will be having a BW3 meet here in the next couple of weeks to show the bad boy off.
On the HID subject. I think i might just say screw it and go with the smoked look. (smoked headlights and fogs, smoked side markers, and possibly tenting my rears)
You would need 2 kits.allensteiner wrote:anyways, i have a 05 bonneville and the lights are setup like r34's (for those who don't know) and i want to do hids for low and high beams but do i have to buy 2 sets of ballasts and bulbs or just a single ballast kit and wire brights and lows together (somehow)? same thing if i ever replaced my awesome glass stockers with r34's - don't want to do a projector retro though.
so here's my prob. i've read that for up to 50 hours one may be a diff color than the other but my passenger is purple'ish. the driver side is grounded to the battery negative but the pass side just to a fender along with an old stock light ground. can that be the discoloration cause? should i ground the other one to the batt - as well or just strip the paint down to metal on the fender ground?kzoosho wrote:Im glad you like them man.
