Are you talkin about when is powers up or after about 3 seconds its still purple? It shouldnt be no where near purple if you got 4300. 4300 is actually yellowish in tru form. Post pics of what you are talkin about and i can further help ya man.allensteiner wrote:
so here's my prob. i've read that for up to 50 hours one may be a diff color than the other but my passenger is purple'ish. the driver side is grounded to the battery negative but the pass side just to a fender along with an old stock light ground. can that be the discoloration cause? should i ground the other one to the batt - as well or just strip the paint down to metal on the fender ground?
also both run of a single 9004 harness plug (male hid hooked up to female stock harness) on the driver side and i thought about splicing in a second male connector for the pass side. would that be a good thing or would it not change anything?
help me man because i suck at eletrical...amongst other things
