docsmile71 wrote:The HID kit for some reason doesnt' stay on with the highbeams. So the pics of the HID from the side are only the low beams. The highbeams come on separately.
That's because the stock H4 bulb has two filaments and has two different terminals on the base of the bulb. The bulb is always on with high/low beams, but different filaments are lit up, and current is provided via different terminals on the connector.
In other words, there are three terminals on the connector, and your HID kit only uses the low beam and ground terminal. The high beam terminal is unused, so when the high beams are on, the HIDs don't get a signal to turn on. If you look at the wiring diagram, you could probably figure a way to keep the low beam terminal hot any time the headlights are on by disabling a relay (just guessing though)
Eric
