whitch fuse?Dori Dori wrote:It's free to disable (pull the fuse) and it's cheap to replace !
Dori Dori wrote:It's free to disable (pull the fuse) and it's cheap to replace (lock bars are like $125). Plus, once it's replaced, you have toe adjustability and no bushings on the links (ball joints and rose joints). It's not really a bad thing...I wouldn't pass up a good car b/c of it that's for sure!
That's something else then. Anytime the Hicas computer senses a problem, it disables it. There's no pivoting back and forth.Tsukai240 wrote:
man it is not safe at all to just simply pull the fuse! if you take a sharp enough turn without the fuse in the HICAS system, the back wheels will uncontrolably pivot. it was pretty scary. the lock bars are essential!
Giant p/s fluid reservoir, extra lines, tie rods connecting to your rear knuckles, a big *** steering rack in the back, a red Hicas light in the car, the sticker on the side that says Super Hicas....the list goes on.Saint wrote:So how do you know if your 240 has HICAS?I an buying one this week, and I don't know where to look.
Yes, there is a failsafe valve for HICAS, but with enough force (of drifting) you could possibly encounter the forces of the car causing the wheels to turn...Dori Dori wrote:That's something else then. Anytime the Hicas computer senses a problem, it disables it. There's no pivoting back and forth.
HICAS steering rack is better. if your nonhicas rack goes out, go with a HICAS steering rack.hamsterball wrote:Why would you want to switch out the steering rack of a HICAS 240 to a non HICAS rack..
the HICAS rack has a shorter steering ratio (i think that's nicer).
I say get the HICAS 240SX. The rack is nice =P And so is a VLSD =P
(I have a non hicas, with VLSD, but i sure would love to have that hicas rack)
This is false, mine was an auto when I bought it, swapped in the 5spd with the sr. Hicas and abs make for one cramped engine bay no matter what motor you have.Meantime wrote:Keep in mind also that the HICAS editions are all manuals, too.
i back this comment up i've known a few automatic HICAS 240sxjustmerging wrote:
