hi all, new to the site and goin well so far...
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
ya the ones that i see on ebay speak of 5 and 6 bolt, i beleive 6 being stock and five being something stronger than the stock 6 bolt (axles i beleive that is)4:1:1 or 3:9:1 or 3:5:1
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
that's from the link that ka-t just supplied
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
240sx with ABS = 4.083'92-'96 J30 = 3.916Z32 = 4.083
They are so close you won't feel a difference.
I think the bolts you are talking about are to the output flanges. The 240sx uses 3 sets of 2, and the Z32 and '92-'94 J30's use a 5 star pattern. I really don't know anything about these, lol, so don't hold me to anything Im saying. I think you have to convert these over to fit a 240sx with different output shafts or axles.
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
Wish I could help too, my knowledge of VLSD etc = none... Try using the button!!!
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
knowing what you are talking about or not, you sure answered some of the questions that i had, it sounds like i should definetely shoot for one from a 240, save some trouble maybe?
1991S13
Yeah it would be easiest to use one from another 240, only problem is you may have trouble finding a true VLSD when most are going to be open diffs. The good part about getting one from a Z32 or J30 is you know they will be a VLSD, because they never came with anything else.
To identify one by looking at it, they should have an orange sticker on the side that says Viscous. Also, if the rear wheels are off the ground you can spin one side and if the other side turns along with it that means it has a LSD.
97ka-t
1998 Nissan Altima
The sticker is not difficult to locate either. Just thought I'd throw that in there
1991S13
Haha.
You forgot to mention when spinning the tire watch for pebbles stuck in the tread. They can tear up soft hands
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
how does the kaaz unit stand up the the vlsd, i'm thinking that maybe i should go with what i know will be a lsd, instead of getting screwed (which sounds very possible), i know you guys are just trying to inform me with what is possible, but damn it sounds a little hard to come across a genuine vlsd
1991S13
A KAAZ LSD is different than VLSD's. Like I explained earlier, Viscous diffs use the silicone expansion to lock the wheels. However, KAAZ (and other companies like Tomei and Nismo) use a clutch-type diff. I really don't know how they work, but you can adjust them according to how easy you want it to be to lock the wheels together. You can get these in 1.5 way or 2 way - 1.5 way applies even power under acceleration and 50% power to the inner wheel when cornering. This is more ideal for beginner. A 2 way gives the wheels equal power under acceleration and deceleration, so the 2 way may be better but harder to get the hang of.
BTW, KAAZ makes LSD's for Tomei, and Nismo does as well, so I don't really think one brand is better than the other.
Here ya go, if you're really serious with your questions call KAAZ - 888-522-KAAZ
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
good stuff man, i'll definetely give them a call!now i just need to find the car and get started!thanks to all for your help!!!!
97ka-t
1998 Nissan Altima
No problem, just drop me a line if you need any more info or IM me.
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
same here, not a problem. My aim is DV96240 , be happy to help you out anytime.
