compression »
https://forums.nicoclub.com/compression-u9345.html
Tue Aug 09, 2005 1:55 pm
I have a Kouki, manual trans, I paid $7,100 for it about 6 months ago.It is in perfect condition, not an SE model, 100% stock, except for an LSD from an SE the previous owner installed. 90k miles, starfire blue.
I did a 5-lug conversion on it, tein springs, tokico struts, enkei wheels, and a front lip, it looks 342% better.
The stock twin cam KA is OK. Its not really that fast, it falls on its face in the upper-rpms, which is where the SR really shines.... but it will get you around town and you will look good in the car.
If you want some cheap upgrades, get the following:-Ebay intake system-header and exhaust system, with test pipe (no cat)-cams. Jim Wolf is a good place to get advice on which cams to get-Have Jim Wolf retune your ECU to take better advantage of your mods.
Probably out about $1500, or less, and your car will be a little faster.My advice is to save up for an engine swap....
But first the hard part.....finding one!
