eddiec »
https://forums.nicoclub.com/eddiec-u12233.html
Tue Oct 17, 2006 9:26 pm
what oil lines exactly do you not have? you need a feed from the filter/pressure sender to the turbo. and you need a return from the turbo to your pan/block. the one in the pic looks like a feed line due to its small size. one end will be small to connect to the turbo, but the other end can be bigger - doesn't matter. just need an adaptor between the source and the line.
auto turbo, sounds like the place on charlotte that may have closed. last time i drove by it looked empty. i'll look tomorrow and see if they are still there. i never visited the store, but the signage indicated they did rebuilds and sourced oem replacement stuff.
are you using alum or ss for your ic pipes?? i dont know directly, however the welding teacher across the hall might do it depending on what it is. if not he may know someone to do it.
you can give me a shout if you want an extra set of eyes to look at it. be happy to help.
