Help with wheels
bigfouroh
Car: 2008 Altima Coupe 2.5S, 1997 Jeep Cherokee, 1967 Datsun 1600 Fairlady
Just wondering if anyone can tell me what the bolt spacing and offset is for an 08' coupe. It has stock 16's on it right now but I'm looking to get 18" or 19". Any info on this would be greatly appreciated. If anyone knows the minimum or maximum offset that would help also.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Man,..doesn't anyone utilize the search button anymore. There has been a lot of posting on this topic.
To answer your question though, regardless if you have 16" or 17" wheels the bolt spacing is 5 x 114.3 or 5 x 4.5 Stock offset is +45 (at least on the 3.5 AC w/ 17" wheels). If you get new wheels that have an offset between +35 and +45, you should be good. As for tires, I wouldn't go anywhere past 245 40s if yo get 18"s. Not sure what tire would be good for 19". What I usually do is go to tirerack.com and bring up the AC and checkout different wheel setups. That way you can get an idea of how it would look on your coupe. It even recommends the size tire you should go with.
Generic808 or Darius have posted a lot info regarding this subject. You should try searching on their posts.
Hope that helps.
bigfouroh
Sorry, looked for the search button and didn't realize it was at the top of the page. Thanks for the help and I'll look for their posts.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
This is the post dangeris is referring to:
zerothread/292641
