Because that's what the package entails. But they said that they can make up a package for me if needed. What do you suggest? I would like to get the wheel out to the wheelwell but without any rubbing during full turn. What off set should I be looking for? I understand the basic concept off offset.( centerline of the rim difference to the mounting hub). but what makes the rim stick out further?..+45 or +35?generic808 wrote:The 18x7.5 will definitely clear. I know 18x8.5's will clear on 245/40/18 with a +45 with a lot of room to spare. I don't know for sure if +35 at 265 will fit, but I would think it would. Why do you want to go 265 on a 8.5? I'd just go with 245/40/18 because they're cheaper
Thanks for your input Darius. I was just toying with the idea of staggered rims. Believe me, I haven't made a decision yet but it looks like I'm just going to go with the same rime tire setup all around. If I decide to go with a 18x8 rim with 245/40/18 tires, will a +35 offset take it out to the fender edge or would a +45 do it. Looking at your last sentence, I would say +35 offset would take it out to the fender. I'm just making sure I'm understanding what your saying. ThanksDarius wrote:There are quite a few things here to tackle from a performance standpoint.
First, a staggered setup on a FWD car is a no-no simply because it will further set the car up to understeer. IF you ever decide to do some spirited curvey driving, the car will not handle as well as the stock setup did. Cars come from the factory setup for understeer to keep people who can't drive from panicking during an oversteer situation. There are ways to stiffen up the rear to make it want to come around better (like a stiffer rear sway bar), but it is something that will only return the car to its previous handling characteristics.
Now you could argue that it is only an inch wider in the rear yada yada yada. Yeah it probably won't make any difference in your daily driving but I'm just looking at it from a performance perspective. Personally, I think it is ricey for a FWD car to put wider wheels on the non-drive tires, and just because ricey VW owners do it doesn't mean you should too. VW owners know the least about performance or they would know better than to be driving a VW.
Second, as far as your wheel/tire selection goes, 265 on an 8.5 inch wheel will look like crap. Not trying to be offensive, but it will look like a fat lady trying to fit into a girdle. I have 265 on my 10 inch wheels (240sx) and they are only a tiny bit stretched. I'd knock it back to 245 MAX and would probably go narrower than that. Why don't you just go equally wider all the way around? And go for a slightly lower offset to kick the wheels out a titch so they're flush with the fender.
Hey generic, when you say tight, ...are you referring that it would look really good or are you referring to as "physically tight" I was thinking of what you were saying about going wider in your earlier post. After looking at the wheel on the online offset calculator, if I went 18x8.5 +35 offset instead, the distance from the strut housing and the inside of the wheel would actually be 3mm less but the outside edge of the wheel will EXTEND an extra 23mm from stock. I believe that extra 23mm will bring the rim out to the edge of the fender. What are your thoughts? I agree with the tires though, I think I'm going to go with 245/45 or 225/45s...generic808 wrote:Darius, there's no way you can get the wheels in a set of four in the same size? If you got four of the 18x8.5, that would be tight. I think that's the perfect set-up to run on the Altima. Just slap some 245/40/18 or 245/45/18 and you're good to go.
I hate to burst your bubble nsrZ32 but I know there is no performance benefits of staggered wheels on a FWD car. I wasn't asking if it'll make it go fast..duh!!! All I was asking is what are the pros and cons...meaning will it damage components in the long run or not, stress parts, etc.. I've had my share of fast cars in my life...and and at my age, I don't need to go fast but spending money on real components that makes a difference is different but on the same note spending lots of money on minimal gains is just stupid! ie..NISMO cat-back exhaust...nsrZ32 wrote:I will attempt to be a voice of reason in this thread, even though you will undoubtedly do what YOU want in the end.
Staggered wheels on a FWD car is plain silly. There is no performance benefit and it is merely for asthetic purposes. You know what mods are that don't serve a purpose? RICE Hate to burst your bubble but spend your money on something useful to make your car faster or perform better.
By "tight", I meant it'll look hot! I really think 18x8.5 +38 would be THE perfect set-up for the Altima. I'm 8" wide, but wish I had that extra half-inch That 23mm would bring you out almost an inch, basically almost flush with the fender.dangeris wrote:
