Rex »
https://forums.nicoclub.com/rex-u6324.html
Wed Feb 25, 2004 7:08 pm
BuddhistWitch - I know you've gone from thiking 2 - 12's to know hearing a recommendation for a single 10, but if you want solid/hard hitting bass and still have some useable trunk, a single HeavyDuty 10 may be your best option.
A single ten, designed for serious power and with a good/decent sensitivity rating, in a well built sealed box, run by a stout 2-channel or mono amp (RF, JL, Phoenix Gold, Autotek, etc) shold give you all you want and do it on a decent budget.
For subs, it's been a few years since I've bought anything, but Kicker, RF, MTX, JL & McCauley are all good quality, durable products. Keep in mind that the first 3 offer an entry/economy line as well as a competition quality sub. You want to go with the upper end, as in any single sub set-up, it will get worked hard.
For amps, (again) it's been a few years since I've bought anything, but RF, Autotek, Phoenix Gold, Orion & JL, are all good quality, durable products. I have first hand experience with 4 of the 5 and have heard good things about JL, though never used myself.
For box, as long as you use the subs spec sheet and build/tune accordingly, you should be happy with any MDF box you build.
I will add that if you do not have plans to upgrade your alt/battery, that you at least invest in a Cap to help both maintain the solid lows and extent the life of your electrical components (Amp, Alt, Batt).
Good luck, and we're all waiting to see some cool pics.
