masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Wed Feb 25, 2004 7:08 pm
BuddistWitch--
Twin subs are the way to go. Yes, a single sub, well placed and powered can hit very very hard, but I think you're on the right track, going with two. I would suggest, however, that you not install two 12" subs... instead go with 10s. Why? Better use of space if you ask me.
Have you considered a dual bandpass box? On a whim, I tossed one into my fastback and it worked really well! Yes, I know you have a coupe. The dimensions on the box I have are 14 3/8" d X 14" h X 26 1/4" w, and it holds two 10" subs. I would imagine that you could make that fit... It would probably fill up most of your trunk space and you can forget using your spare... LOL, but you might consider it.
As far as the RF amp, that's a great choice. It'll be more than enough to power a couple of good subs... but what subs? Well, that depends on what frequency range you want to explore. For instance, Infinity Perfects have a very low range (20-200 Hz, something like that) while Sony Xplods have a HUGE range (18-3K Hz, I think.) I wouldn't recommend EITHER for regular performance (Infinity lacks range, and Sony, well, Sony should stick to PS2...)
Once you get the same level of detailed specs on a subwoofer that you have on the RF amp, your decision will be pretty easy.
