netwiz813 wrote: I'm somewhat mechanically inclined and thought that I would save myself some bucks and attempt to change my starter and fuel injectors, which I had diagnosed and found to be faulty. I wanted to ask for my 1989 240sx SE, is it really hard to install fuel injectors, if so when I decide to replace them does anyone have any comments of things that I should be on the look out for or should I just have it done at the shop. I've replaced a starter once on my VW but was wondering if replacing a starter on my 240 any more complicated than the VW. Also, I plan to replace my altenator in about a month and was wondering if I could get some tips on replacing, thanks in advance . Does anyone know of a good manual that I could purchase
Cakewalk. Injectors unscrew from the fuel rail, just unplug the harnass and unscrew, youre done there. Alternator is easy to unbolt, and theres 1 plug and 1grnd post to disconnect wires from. Starter isnt hard, getting your hands where it is can be tricky. 2 bolts, the harnass and youre done with it. Shouldnt take more than 2 hours for all of this, and thats with a few smoke breaks. Goodluck.
