LakaiOrDie »
https://forums.nicoclub.com/lakaiordie-u223904.html
Wed Sep 11, 2013 8:14 pm
i searched a lot, seems the most un discussed issues happen with me but anyway,
the passsenger side headlight wont respond to button or headlight switch... the drivers side is fine.
when i had these motors unplugged all winter they did both work flawlessly, im going to try cleaning connectors tomorrow, but
when i play with the twist knob on the bad side, there is free motion no binding or catching on things it will move. then when it reaches a popped up position, its immediatly flipped down by itself. so theres power, i checked continuity, pottentionmeter contacts ive no idea what is the problem
the signal for the two lights is transmitted individuallly or shared between them? like from the dash switch, or how does itr work i also will try switching relays tomrrow please anyone chime in with some help or advice i need it when it comes to electrical please. thanks
