IanS »
https://forums.nicoclub.com/ians-u23642.html
Tue Jun 05, 2007 4:40 am
how are your fans wired up, many people use switches because there isnt an output on the ECU that controls the fans, if the thermostat was bad the engine wouldnt be heating up, it is not you problem, it is either your wiring, or it is the temp sensor or relay that control your fans that is messed up
