help with 22's on 03 q45
lewisgs22
Hello guys,
I put on 22's on my f50 and the wheel rubs against the strut base/lower portion of the spring. what are ppl doing to remedy this situation. I really dont want to return the wheels.
thank you,
Lewis
Rex
Car: None
Very few (if any) members run wheels that large.
My guess is you have 2 options, if there's enough outter clearance, run a small spacer to gain the necessary inner clearance. Or return them.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Lewis, be sure to complete your profile.
I guess you have to decide if wheels or your car i more important to you.
If your car was too fast before, you could sell it. If you prefer the wheels, you could build 4 uniclycles, I guess.
BLACKonBLACK98
Car: Q45, LS400, STS-V
spacers.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
You need to post the offsets of the rims. If you can return them, do it. If not stuck with them than looking into spacers.
If you can exchange them drop down to 20's in the right offset.
gjh20
Car: 2005 G35 Coupe, 2005 350Z Vert, 1989 300ZX
other than wheel offset, i think the most crucial question is "what size tire do you have?". if the wheel is rubbing w/o a tire, then a spacer (preferably hub-centric, custom measured/machined to fit car AND wheel) is your only hope. i have put 22's on numerous F50's at my shop with no problems so i know its entirely possible with the correct fitment.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
gjh20 wrote: i have put 22's on numerous F50's at my shop with no problems.
With tires meeting OEM minimum load rating specifications and correct rolling diameter? How much over stock wheel and tire combination does it weigh?
Modified by maxnix at 6:24 AM 8/6/2008
gammer_ghn
Why do you need 22" rims if you dont know how to put it on and have it work for you?
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
spacers+extended studs depending on how bad it is
return the wheels if possible... and if you absolutely must go with 22"s go with these guys
http://www.vipmodular.com they know exactly what it takes...
and next time do your math before you buy!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
gammer_ghn wrote:Why do you need 22" rims if you dont know how to put it on and have it work for you?
No one needs 22" wheels, they just saw Poop Daddy's Hummer and wanted to hang with the middle school drop outs too.
carnal_c30 wrote:... and if you absolutely must go with 22"s go with these guys
Any wheel manufacturer who does publishes neither weight, strength nor manufacturing techniques for its wheels is not to be trusted.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
bottom line is, the wheels are NOT suited for the car. Its like buying a pair of shoes and you bought them in wide instead of normal.. you would take them back and get normal, instead of just wearing 2 pairs of socks... You CAN wear 2 pair of socks but the shoes are never going to fit your feet how they should.
Same is true, even with spacers its just "making it work". Spacers generalyl arent a good idea, however you may not need that much spacing. If the wheels are brand new you probably want to return them. By the time you put in longer studs to adapt even a thin 5-10mm spacer, you're going to be in another 2-3 hours of labor for all 4 corners.
We really need to know the wheel width, offset, and tire size.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
And wheel weight, strength, tire load rating and weight. All the important information.
TBrack
Car: none
is the wheel or tire rubbing? you might have to get smaller tires, but I agree that 22 is way too big for these cars.
Rex
Car: None
maxnix wrote:Any wheel manufacturer who does publishes neither weight, strength nor manufacturing techniques for its wheels is not to be trusted.
VIP Modular wrote:... the structure of each wheel begins life as a forged aluminum disc of aerospace grade 6061 heat treated to a T6 hardness. From there, the life of the wheel progresses onto a CNC (Computer Numerical Control) mill where the design is machined into existence. Once machined and quality tested, the VIP Modular centers are then sent to a separate facility to be personalized with plating or powder coating procedures. Then, the centers are hand assembled at VIP Modular with 6061-T6 rim halves using only the highest quality fasteners and valve stems, and then hand torqued to exact specifications.
Seems like they describe the manufacturing technique??
A little research would show you these are high end (MB/BMW) 3 piece forged wheels.
Not that I think 20" (or bigger) wheels belong on a G50/Y33.
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Why stop at 22's when 24's will fit?
http://sfbay.craigslist.org/eby/car/778712627.html
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Q45denver wrote:Why stop at 22's when 24's will fit?
Oh....my....
qship96
Car: 1996 Infiniti Q45
paranoidjack wrote:
Oh....my....
Qhetto Q !!!!!!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
No weight or strength specifications. Titanium bolts like OZ racing? What kind of seal? HRE are real bad about sealilng. Expensive but crap. Why they are not raced.
Forging is good, but at what PSI? It all adds up. Basically, if a top team is not using it in an sanctioned racing series, it should be suspect. One can start at F1 and go down. Some, even Rays and especially Enkei, make some great wheels and some real average or even below average. BBS, Fikse, most OZ Racing, SSR, most Weds, very few Work are worth their price. Most others are poseur wheels for show and not go.
Modified by maxnix at 10:20 PM 8/7/2008
szh
Car: 2018 Tesla Model 3.
Oh, gross!
Z
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The wheels are certainly bad, but the reason my lunch is now embedded in my keyboard is that HORRIBLE wood grain kit. It's not the wood grain itself, it's thar particular kit. With that one stick-on part, the Q went from lux to Ford Taurus in zero seconds flat.
gjh20
i figure that since everyone is already on their "what is too big" kick, that this is as good a time as any to debut my new changes to my '98.... the wheels are NC Forged 7-spoke (ignore the MHT ctr caps, i have custom floating ctr caps that i'm going to paint/install once i redo the whole car). fronts are 22x9, et15, w/235/30-22 ToyoProxes PX4s. rears are 22x10.5, et15, w/265/30-22 PX4s. the wheel color is burnt orange (don't ask why, i wanted it different. SOOOO tired of blk on blk, blk/machined, blk/chrome! no pumpkin/halloween jokes plz. a coworkr of mine is the lamest dude on earth & has worn em out). i have no rubbing or scrubbing of any kind. i can turn lock to lock with no problems. the car is also lowered 1.25". i have 4" front lips, 6.5" rear. the effect on the car is stunning. i know its not you guys style preference, but mechanically the car functions beautifully & there is NO OTHER Q that makes S-classes & 7 series pay as much attention....
NightRiderQ45
Car: 1998 Infiniti Q45
Man, that's nice and classy. I didn't you say that you custom cut your springs for the drop. Once I'm back in the A again, I will give you a call asap! Email me....I want to speak with you about a couple of tire prices and maybe to drop mine. I have 20"s, so I would love to have mine dropped to kill some of the fender well space.
qship96
Nothing a $3.99 can of silver/charcoal spraypaint cant improve, except the size.
gjh20
qship96 wrote:Nothing a $3.99 can of silver/charcoal spraypaint cant improve, except the size.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
gjh20 wrote:i figure that since everyone is already on their "what is too big" kick, that this is as good a time as any to debut my new changes to my '98.... the wheels are NC Forged 7-spoke (ignore the MHT ctr caps, i have custom floating ctr caps that i'm going to paint/install once i redo the whole car). fronts are 22x9, et15, w/235/30-22 ToyoProxes PX4s. rears are 22x10.5, et15, w/265/30-22 PX4s. the wheel color is burnt orange (don't ask why, i wanted it different. SOOOO tired of blk on blk, blk/machined, blk/chrome! no pumpkin/halloween jokes plz. a coworkr of mine is the lamest dude on earth & has worn em out). i have no rubbing or scrubbing of any kind. i can turn lock to lock with no problems. the car is also lowered 1.25". i have 4" front lips, 6.5" rear. the effect on the car is stunning. i know its not you guys style preference, but mechanically the car functions beautifully & there is NO OTHER Q that makes S-classes & 7 series pay as much attention....
Not a fan of the color etc, but the thing that really hits me is that to pull off 22's on a Q at all... you need to be lower with more camber and some form of aero... if you were going for the flush look smaller/higher offsets would have been a lot better in my opinion
As for a lot of the comments... these cars are ~3900lb... heavy wheels aren't going to be a huge deal so roll what you want in my opinion (coming from a guy with CE28N's on his S13 that weigh under 14.8lbs for 17x9F and a bit more for the 9.5's in the rear). That is of course unless you are making the car into a sports sedan... I'm all for lighter wheels, but I don't think heavier wheels are a huge deal on this car especially the F50's (they are huge!)
As for Lewis... sounds like you need a spacer if you must keep the wheel... if you have room between the fender and the outer edge of the tire/wheel that is... go to a reputable wheel shop in your area to see if you can get an "expert opinion" on how much you'll need and if you'll need to roll/pull the fender (I'd imagine there's a parcial hem on an F50 so probably not much you can do for a roll... but it's worth asking)
As for that "VIP Wheel page" they just look like another knockoff or carbon copy HRE/360 Forged company to me...
Side note:Is that a ASMA Shark I kit on that CSL? Not a fan of the look... but hella rare (which makes it cool in it's own way)! Thing needs wheels BIG TIME
Modified by rbsileighty at 7:27 PM 8/8/2008
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
rbsileighty wrote:... you need to be lower with more camber and some form of aero...
Two quotes that tell us this poster does not undertand correct tire alignment for wear and performance and has no clue about unsprung rotating mass.
marksport
lewisgs22 wrote:Hello guys,
thank you,
Lewis
Lewis, sounds like you got a wheel package that would fit on the 300C/Charger. If that's the case, that's where your problem is. What size tires are you using? To run 22" wheels on the F50, you have to use very specific tire size and possibly even certain brands depending on the actual tire specification.
rbsileighty
maxnix wrote:Two quotes that tell us this poster does not undertand correct tire alignment for wear and performance and has no clue about unsprung rotating mass.
Ha... this works well when you leave out the part about the wheels on my S13
This is a Q45... not a M5... not even close. Don't get me wrong I love this car (which is why I'm looking at getting one or just doing the payment thing again and getting an E60), but being a Q45 guy you should know the VIP heritage of this line from Nissan. Maybe that guy's choice in brands isn't there, but the look is on the right track.
I'm just trying to help... even if I don't like the particular details the owner's chosen... b/c that's what forums were started for in my opinion.
Maybe the best thing to have done was to move this to the VIP forum instead of bash the guy... and people you know nothing about who try to help make what he wants work for him
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
gjh20 wrote: fronts are 22x9, et15, w/235/30-22 ToyoProxes PX4s.
Front tire load rating of 90 is 1323 lbs. at 50 psi, well below the the OEM recommended minimum of 94-95 1477 lbs.-1521 lbs.
Shame people are more concerned with color and lip than proper alignment, strength, weight, what the owner's manual specifies as minimum, and never read the tire's sidewall.
rbsileighty
maxnix wrote:Front tire load rating of 90 is 1323 lbs. at 50 psi, well below the the OEM recommended minimum of 94-95 1477 lbs.-1521 lbs.
See... now that's helpful
