q45ondubs wrote:so what do i ask for if i want to put 22inch rims on a 1998 q45 and what size tires..do you have any idea...
i know EXACTLY what to ask for! i have it!!!
i don't think the best look for this car is a high offset (+35 or higher). depending on the look you are going for, i like my wheels to extend all the way to the fender lip without sticking out. when i built my wheels i found that an offset of around +15 (similar to Magnum, Charger, 330C setup) filled the space very well. more than that, and depending on tire size, you risk rubbing. (note...i rolled my rear fenders) as far as wheel widths, it depends on whether you want to go staggered (preferred in my estimate, though no tire rotations without dismounting/flipping tires) or not. if not, a 22x8.5 or 22x9.0 will work all the way around. i don't think you can effectively go larger than a 255/30-22 tire in that setup. if staggering, 22x8.5 and 22x10 is optimal. if you want to be aggressive (as i did) you can push it with a 22x9 and 22x10.5. tires on my setup are 235/30-22 front, and 265/30-22 rear. the tires are slightly stretched so as to stay clear from rubbing since i do have the car lowered. you could also go 245/30-22 on front for slightly more rubber, just beware of the strut tower as you will barely clear it.
anything else i can help with, just ask. i think these cars look great with a wheel that is proportional to the size of the car. check out Dirty Larry's car as well...sick!
and fyi, you don't have to go with those "teenage" or "not legal to drink" sized wheels to lower the car and achieve a sick stance!
