Summer tires should never be used in snow or they will be ruined forever and dangerous to ride with. The compounds that make up the tires will freeze when they get below 32 degrees and will harden, loosing most of their grip and will wear badly. Even after they thaw out the tires will never grip or wear as good as they used to because the compound froze up. All-Season tires will not freeze like this and are rated to 0 degrees or lower. However, A/S tires dont always have the same grip that a true summer tire could give, though these Michelin's I have now are actually equal to the best summer tires I have used. Which was pretty surprising to me.DS2009m35x wrote:Car has this offbrand summer HP tires which were scarry last winter in the snow. Yes, summer HP tires are not meant for snow, but I didn't think it would be as bad as it was. Pretty much decided to buy snows on alloys for this winter.
Im going to try doing this soon and see what happens, though tramlining is 99% gone with my tires anyway.Mykel6 wrote:2) Tighten the steering rack screw (little bit) as described in this thread by user "filet" (scroll down the thread).
steering-wheel-shakes-40mph-t547763.html
Steering does not feel as loose and tramlining reduced. I guess tightening this stops the road from easily pulling the wheels left and right.
I'm going to call BS on this. What proof of this do you have? I'd take an article from any reasonably trustworthy car magazine, the NHTSA, IIHS or a white paper from any of the major tire manufacturers.EniGmA1987 wrote:Summer tires should never be used in snow or they will be ruined forever and dangerous to ride with. The compounds that make up the tires will freeze when they get below 32 degrees and will harden, loosing most of their grip and will wear badly. Even after they thaw out the tires will never grip or wear as good as they used to because the compound froze up.
LOL. You serious bruh?psyopper wrote:I'm going to call BS on this. What proof of this do you have? I'd take an article from any reasonably trustworthy car magazine, the NHTSA, IIHS or a white paper from any of the major tire manufacturers.EniGmA1987 wrote:Summer tires should never be used in snow or they will be ruined forever and dangerous to ride with. The compounds that make up the tires will freeze when they get below 32 degrees and will harden, loosing most of their grip and will wear badly. Even after they thaw out the tires will never grip or wear as good as they used to because the compound froze up.
I hope that's what he's referring too otherwise...STAY OFF THE ROADS WHILE I'M AROUND you driving-on-snow-with-summer-tires-bad-driver-guy-you.jiggersplat wrote:i think he was referring to the claim that once they get cold/freeze they are never the same again even after they warm back up.
