that would be my guessblinker_fluid wrote:maybe a bad pcv valve???
my stock oil catch hose connect to the tee to the valve cover but the other side of the tee has no hose. so i just cover with a bypass cap. is that normal?cheapscheisst wrote:sounds like your head might need to breath. did you plug up the venting tee (the other side goes to the catch can)?
where is the pcv locate?blinker_fluid wrote:maybe a bad pcv valve???
i notice that there was leaking alittle bit of oil. let me try to tighten up alittle bit. I remember that I used to have individual throttle bodies from gtiR and custom manifold (regret it for trade) and i replace it back to stock sr20 and probably the guy that swapped it he might of not tight it enough. let me check it out. hopefully that solve the problem.mrzabala wrote:Far left corner on the valve cover. It connects to your intake manifold right behind the fuel rail.
