S14-KOUKI-MONSTER wrote:Why do you want to remove the fuse for the fuel pump? Is your car not starting? Include more info or people have to guess and assume.It's in the fuse panel, to the left of your pedals. Read panel for location. Your fuel pump relay is under the hood in the fuse box. How would that help you check the fuel pressure? I'd want to see what the pressure is throughout the rpm range.
I just want to check to see if the fuse is busted and cause my car idle for a few secs and cuts off.. Just wanted to see if im getting fuel into the car..
