help replacing power window motor
bigreese
i am looking for a motor for the driver side window. has anyone replaced one? does anyone have one for sale
Rex
Car: None
bigreese wrote:i am looking for a motor for the driver side window. has anyone replaced one? does anyone have one for sale
Check the Classifieds as there are a few Q's being parted out. Make sure you mention what year and door .
zeroforum?id=172
zerothread?id=43044http://forums.nicocl ... d?id=31465
Do you need help on how to remove the door panel?http://www.carstereohelp.com/s...e.htm
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Are you sure it is the motor, and not the regulator? If the window is not rolling all the way back up, then it is your regulator. If the motor doesn't move at all, or make a noise, then it is the motor.
I have replaced 2 window regulators, but the motors have been fine. I bought new, from Everythinginfiniti.com. About $85 for the regulator.
It is a simple replacement procedure. It takes about 1 hour:
You slide off the arm rest, pry off the window control panel carefully, remove the screws, pop off the door panel, peel back the plastic water barrier (don't tear it), remove the Bose speaker assembly, then remove the 6 bolts that hold in the window assembly (you will have to lower the window, to get to all of them). Once you get it out of the car, you can then replace the motor or regulator assemby. You will have to disconnect all the harnesses along the way.
There are some pics in previous threads. Do a search for "window regulator".
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
I changed the regulator a while back. Here a like with some good directions that Jeff gave me. Check it out.
zerothread?id=102028
