I didn't even think of that, but that sounds exactly like what's going on...jeff420 wrote:are you sure you have an lsd and not a welded diff?
yeah im sure its a lsd... i replaced the gasket and checked the gears inside.jeff420 wrote:are you sure you have an lsd and not a welded diff?
YEP!You got a welded diff, not a LSD.unibody_s13 wrote:im not smashing my gas...
ok dis is how things happen... lets say im in a mall's parking lot leaving.im backing up and turning my steering to back up. while im gasing to back up, my rear tires spins losing traction and rear shakes.its not normal.im not accelerating that hard.but whenever i drive straight my traction is fine-no shakes or pops.i dont do everything at the same time(steer,clutch,gear,accel etc.).
i got the lsd from the shop where i bought my front clip. actually wuts weird is i drove for 40 mins saturday to go to my friends haus. when i got there i tried to parallel park and i didnt experienced the wheelspin and shaking and i was soo happy. and when i was about to leave after 4 hours it happened again, when i got home its not happening again. idk. i also bought subframe bushings that i dont really need but checked my bushing were stil ok...modulation wrote:
Did some one sell you that "s14 lsd" ?
Do you notice it in parking lots alot?
im not sure but it looks like it but no signs of welds. i tried to compare it to my open diff and the gears are different.modulation wrote:Do you have any pictures?Maybe the VLSD failed and then they welded it..
Does it look like this?http://is.rely.net/3-99-7267-l...w.jpg
if its bad does it only happen when turning or cornering??? or can u also feel it going straight?modulation wrote:It's the LSD for sure dude, my friends 510 with a welded diff does the same exact thing..
It might not be a welded diff, but a LSD that has gone bad or something..But it's something with your diff, I'd bet $100 (if I had to it.)
if its a bad lsd will it produce unusual sounds? i searched about lsd problems and all of them experience whining and grinding sounds... my differential is quiet... you can hear the tires spinning... oh and also i filled it with lucas 80w90 gear oil.it says in the bottle "great for lsd" without adding the additive. so i didnt put any. u think adding the additive will solve it???modulation wrote:With a welded diff when you are going straight it doesn't do anything (because tires are turning at same rate.) It's only when you turn. (Cause the tires spin at different speeds.)
But if you have an LSD and it's gone bad or something then I have no idea what it would do. (besides act like a welded diff in certain circumstances.)
ok lets say its welded... is it safe to drive? i checked under my car last week and the right knuckle where the hub bolts on was loose...jeff420 wrote:you dont need an lsd additive, the vlsd is a sealed unit. im willing to bet its welded.
everything you described points to a welded diff. about your driveshaft bein too long, ive never had a problem using a vlsd with a non abs driveshaft, and ive done a few.
You're a moron, you must goto UF.Nissan VLSD's are SEALED UNITS. They don't require VLSD fluid as me and some one else above already said. The VLSD disc and fluid are sealed in a separate unit. You just add normal gear fluid.SullivanRacing06 wrote:she got to much power captain!!
check the rear end fluid, when you refill the pumpkin add friction inducer so itll let the vlsd wrok better
Did you tighten those bolts that you saw were loose?But either way it sounds like you have a welded. And it is perfectly safe as long as the guy that welded it knew what they were doing. I daily a welded and i have no problems with it kicking out on its own. As long as you dont drive like an *** you shouldnt have a problem.unibody_s13 wrote:
so how can i reduce the wheel spin when turning?
Damn so you are so stupid you couldn't even get into UF?You goto Santa Fe?SullivanRacing06 wrote:
yeah me and my dad torqued it... i used an impact gun to tighten and a torque wrench to torque... i just dont understand why it came off... its scary! yeah ill keep it if its welded ill also try changing differential fluids just to be sure... im not a wreckless driver so i guess im okay!LayNLow240 wrote:Did you tighten those bolts that you saw were loose?But either way it sounds like you have a welded. And it is perfectly safe as long as the guy that welded it knew what they were doing. I daily a welded and i have no problems with it kicking out on its own. As long as you dont drive like an *** you shouldnt have a problem.
That's pretty much true. Well, not totally. The area around the college is nice. Move out toward Archer, Newberry, or East Gainesville, however, and man, white-trashy.modulation wrote:
Cause I know, no one would want to live in the hick *** white trash town of gainsville if they aren't going to school there..
UF is a joke.They try and pretend to be all prestigious so that people think they are a top school but they aren't, and outside of Florida people laugh when you say UF like it's M.I.T. or something its just another state school get over-yourself. Everyone that goes there thinks they are going to harvard or something but it's yet another state school and the haughtiness and people walking around with a stick up there *** like they are gods gift to this world gets old real quick.charlieo wrote:
UF's a killer school though, thanks for playing.
i dont remember how much i paid... but i got it with a deal with my front clip...modulation wrote:I'm no expert of welded diffs, but I believe you should be fine.It's annoying in parking lots, calls alot of attention to you, but no biggie.
Just be extra careful going around sharp corners in the rain.
How much did you pay for the LSD though? Or did it just come with the car.
