HELP - Problem with Heater and Thermo Gauge
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Help guys!
First let me say Merry Christmas and Happy New Year. I haven't been around much lately. They're working my butt off here at work and kids keep me running at home. But I lurk occassionally and need some help.
I've got a problem with my 94 Q. I started noticing my temp gauge running hot the other day - almost all the way to the very top and the heater was on blowing cold air. Then as I got on the highway and RPMs got up around 2500 or 3000 something happened and the heater all of a sudden started working and instantly the temp needle dropped to normal. Then as I got off the highway and started coasting it reversed itself. What's up? Do I need a new thermostat?
Thanks ahead of time guys.
yodawill2000
Car: 94 Infiniti J30
Have you checked the coolant level ??My ole' truck used to do that when it was WAY low.
AlabamaDan
1998 Infiniti QX4
yodawill2000 wrote:Have you checked the coolant level ??My ole' truck used to do that when it was WAY low.
Yeah coolant level is fine. In fact I put some more in it and it it was over full making a mess on the garage floor.
96Qowner
Car: 1996 Q45
First thought is thermostat, but Dennis said this:
Q thermostats fail open and don't let the coolant warm up............common condition in winter.
zerothread?id=205495
Still, can't hurt to change it out.
qship96
Car: 1996 Infiniti Q45
waterpump not circulating coolant through engine { hot} and heater core{cold}
goody90q45
Car: 1992 Infiniti Q45 (sold)
Is the engine fan running at idle? Fan clutch? Still got 3 belts?
AlabamaDan
1998 Infiniti QX4
Still haven't solved this problem, but I have another possible cause. Last night when I got home I smelled a burning rubber smell, like a belt. What if one of my tensioners has gone bad and isn't turning the water pump consistently? Then when I get up to higher speeds it does turn it some? I haven't heard any squeeling.
Thanks guys.
