TooTallB wrote:No that is a negative but what you can do is use the internales of the KA put into the casing of the SR. I also have an 89 with the SR swap and the transmission went so we switched the internals. but no you cant bolt the KA up to the SR.
if you dont know, dont post, the transmission cases are the same, it is only the bellhousings that are differant.
to the OP, there is lots of information about this if you use the search button, all I had to do was scroll down and I found this.
zerothread/278158
