I am by no means saying 26 amps is out of the question. I have seen it before on light trucks. 12 or 24 volt, a key off draw of 26 amps is MASSIVE. A typical vehicle will have battery drain issues from anything more than a single amp draw.Chaotic_Warlord wrote: FlatBlack, 26 amps on a vehicle like this isn't out of the question, especially if it's a 24V system. Remember, this is a specialized service vehicle, it needs to power practically everything you would find in an ER, EKG's, defibrilators, oxygen pumps, a ton of computerized monitoring equipment and life support systems. Plus I do believe thet have aux. docking stations to plug in 110V and 120v power cords.
Nice mention of the glow plugs, but I would think that if that were the case they would burn up or burn out and then they'd have a much larger issue at hand.4cefed wrote:Finding power drains is even less fun than opening the ark of the covenant and looking at the contents.
Do like Ian suggested. Are they truly 24V systems or do they just have 2 12V batteries? There is probably a distribution block somewhere for all that equipment. If you can't find the drain by pulling all the fuses, you may have to unhook cables connected to the positive terminal(s?). I would bet there are multiple fuse panels or distribution blocks throughout the vehicle.
If you discover what fuse/leg it's on, see what equipment won't work anymore and start playing with that stuff. Chrysler liked using these "fusible links" on stuff back in the day. They look like normal wires, but they contain a piece that will melt on an overcurrent and break the wire. I don't know if they are used anymore or if Ford used them, but that would be something that would have to be unbolted or physically disconnected somehow.
For a quick fix while you are finding the culprit, you could install a master battery disconnect, they make a nice rotary knob connected to the positive terminal. It would reset the vehicle's ECM every time, that may not be healthy, but having a dead ambulance when someone's life is on the line could be worse. Hope you get it solved.
The glow plugs aren't stuck on are they?
A "Draw" cannot be measured in volts. Only in Amps.Chaotic_Warlord wrote:
Depending on which company built this ambulance (it sure as hell wasn't built by Ford) the circuits and wiring diagrams will be different from builder to builder.
Also Are you sure your CO said their was a 26 AMP draw, or a 26 Volt draw? There is a HUUUGE difference, 26 volts tickles, 26 amps is fatal. Just sayin'. When you replaced the alternator did you go to Autozone and pick up one off the shelf or did you actually order one specific for ambulances? If you just threw in one meant for a diesel E350 that Bob the plumber uses it's not going to be strong enough to fully charge the battery, so every time you go on a call and actually put some strain on the battery it's going to pull what little life is left in the battery to require a a jump next time you get a call. In the event that you are actually using the correct alternator verify that it is wired correctly, if the polarity is reversed then you're definitely going to have a power draw.
Not sure what cities you are referring too, but the VAST majority of ambo's that I've been in have nothing like that on them. Yes, lights and sirens take up a lot of power, same with the flourescent lights, huge A/C system, radio's, GPS, etc. But our EKG is a portable monitor that's powered by 24v Dewalt batteries, defib unit built into that monitor. Besides, defib doesn't take very much energy to use. O2 pumps, nope. Just an o2 bottle that is turned on manually and has a regulator on it, nothing electronic there. And I really don't know what other life support system's would even be on an ambo. We can't do a whole lot in the field. Mainly hook them up to the monitor, check vitals, throw them on high flow o2, start an IV, push some drugs, and haul a** to the ED. Honestly, not a whole lot else we can do.Chaotic_Warlord wrote:
Just curious, but how many have you been in? It sounds like thousands from the way you make it sound...ADDirishboy wrote:the VAST majority of ambo's that I've been in have nothing like that on them.
Phoenix- about 4Dattebayo wrote: Just curious, but how many have you been in? It sounds like thousands from the way you make it sound...
