FSUDrifter »
https://forums.nicoclub.com/fsudrifter-u36244.html
Mon May 07, 2007 10:53 am
Okay, my car was running fine. I pulled the engine to change the front cover and re-do the gasket.
I put everything back together and when I start my car, it idles up real high, then falls down and cuts out. I can't get it idle steadily. When I rev it up it hesitates a little and when I try to hold it at a higher rpm level it pulses.
I did take out the CAS to get to one of the sub-bolts holding on the front cover, I tried to put it straight back in, but I'm not 100% positive if I put it back right. I would think it might be off a tooth, but it starts and runs ok for a second, I would think that it would run like absolute crap if it was off a tooth.
I'll post a video in a minute.
Please HELP, I really need to have left about 2 hours ago.
