There you go. That's your problem right there. If you lined up the crank and cam correctly as you said above, the rotor (side with the metal piece) SHOULD BE POINTING TO 5OCLOCK, which is around the vicinity of the #1 spark plug wire connection.lbrowne wrote:bruinbear: being that i'm in the IT industry and I'm fairly knowledgeable with it, when i talk to certain people about things i too have to make sure i ask certain questions, even though it may sound like i was being insulting....so i do not take your comments in vain
she has good oil and my timing chain is perfect but i think i've found the problem.
all the plugs were wet with gas after i tried to crank her, so fuel was getting in. eliminated the fuel pump at this point. i get spark from everything, eliminated plugs, wires and coil
now i just had my gf watch the sprocket with the silver links as i cranked the engine from underneath till she lined up to TDC. keyway pointing straight up, dot pointing to 3 o'clock with the silver link on it. (i had the plugs removed)
i took the top off the distributor and it is pointing to number 2, or 7 o'clock so to speak. not #1 which is 5 o'clock.
so i guess my rotor is screwed, so for just under 50 bucks i can change my cap and rotor and thats what i'll do tomorrow.
i've never done this so how to i get it to line up? i would need some help here....and you've guys have brought me through thick n thin.
ps: what would cause the rotor to do that? just went bad? the car did sit for over a year+...so i'm thinking it just deterioated (sp?) over that time and from the extensive driving i've been doing the last little while it failed.
i hope i never washed down my engine....but after hauling out the dipstick, its a nice clean oil...nuthin runny...
Cyberkreig wrote:Sounds like good news, Maybe when that screw came off the Distrib just got wrenched out of position? Someone correct me if i'm wrong.. but if the car is at #1 TDC, and the Distrib is at #2, all he has to do is take the D out, spin it to #1 and put it back in. When you do that (if i am correct) be sure to set it one tooth back from where it "should" be. You'll see that when you slide it in it will advance to teh right spot.
Think of your tools as a fixed cost and shop time as a recurring cost. Your tools will serve you every time you need them; a shop will take your money every time you need them. Don't get me wrong; I maybe had 2 screwdrivers and a Swiss Army knife when I was in college. Just something to consider later when you have more money and time than you do now.lbrowne wrote:i have an appointment for this friday for a shop to look at it, because the amount of money i would spend in tools would cover what they would charge for the hour to troubleshoot her.
i've had a few people say that the fuel pump more than likely the culpirt because it doesn't matter if its sending *some* fuel. if its not at least a certain amount of psi it ain't gunna go. i think i read somewhere it has to be at 45 psi for the 240sx.
tonight i'm going to turn her to tdc, check my spark timing, and i got a compression tester to check my compression. might as well i spose.
do i just take out the plug, plug the tool in, crank her and get out and look at what it reads? or do i need someone to crank her while i watch the gauge...
