float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Oct 15, 2009 2:46 am
Use the stock turbo manifold. I wish I had kept mine. The tubular bottom mount doesn't really gain you that much and it makes the turbo spool slower.
No point in a wastegate with the S15 T28
If you get a a good chip, you shouldn't really need the neo. Your local tuner should be able to rechip the ecu for your car on the dyno if it's that far off, but it shouldn't be.
You can use the Felpro HG, it will work just as well, and costs less.
I'd spring for the ARP rod bolts before I'd get the head bolts. They're the weak point. Or you could get both, lol.
I'm using a SPEC Stage 3+, but some ppl don't like spec's because the pedal pressure is really light and the friction point is in a weird spot, but once you get used to it, it's better IMHO.
