blackandblue »
https://forums.nicoclub.com/blackandblue-u123334.html
Mon Dec 21, 2009 4:15 pm
replacing a strut with an identical unit will give you the same problem. Don't waste your money on a new strut. If the car bounds or is obviously leaking oil from the strut, it needs to be replaced. If not... I would recommend fitting up S13 struts on the S13. I don't know what spring rate differences or fitment issues you could expect from S14 struts on S13's. Similarities abound but, I know for a fact that LCA's are shorter on S13's. The geometry differences might be enough to cause serious problems. If you haven't consulted with an experienced professional yet, now is the time. I am a one car garage, shadetree guy with limited tools, but 10 years experience on the S14. My car has been to the shop for tires and that's all. 120,000 miles since I bought her!
