HELP!! Lost Key, Need To Tow, Won't go in nuetral
xStreetMoney
Car: '93 Nissan 240sx Hatchback SE
Hi Guys!
I need a hand on this one. I lost my damn keys and need to tow my 93 240sx Hatchback. I thought there was like an emergency release or so so you can put the car in neutral. Anybody got a know how on this... I would sure appreciate any help on this one!
Thanks guys!!!!!!!!!!!!
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Many cars have a small hole next to the shifter that you can stick a a small screw driver in, and release the the shifter. Some its a hole,.some you remove a small cover, and some you have to remove the boot or trim to get to it.
xStreetMoney
do you know exaactly which one of those it is specifically for the 1993 nissan 240sx hatchback se?
compactfean
daily
It must been 10 years since I've worked on a auto 240sx.... Idk. Check this out though.
diy-stuck-shifter-wont-come-out-of-park ... 54005.html
biggie
Should be a little button on the front of the shifter at the base of it.
