OK the car is coming along good
few more Q's
STATER- it does start up but it's a sharp starting noise and at time takes a few cranks. Sounds like the starter is going... any tips appreciated
RACK AND PINION- Loosing power steering fluid easy diagnose rack and pinion is leaking, question is should I get it rebuild or better new
? allot of $$$ either way.
SHIFTER-There is a release press needle along the automatic shifter, i'm guess the cap is missing on it and i have to use a screw driver to shift from drive. Is that normal or should it shift once you apply breaks? is there diagram on the shifter?
Steering Wheel- Honk does not work, not sure if it the SW or something else but the SW is not in great shape. Is it suitable to but a SW from a 93 if it a airbag into a 90? What else can I check to get the horn working?
RADIO, any instructions on installing a radio? i guess it was stolen just before i bought it, missing the face of the detachable
