HELP! JB weld
drftsx
Car: 90 240sx(sr)
yesterday i dropped my timing chain tensor and broke a portion of the bolting side. id like to know if im able to jb weld it back together. THanks.
SpeedRacer1
Car: 1990 240SX, G35
Anything is possible, but I would just replace it anyway. Nissan upgraded this part later on with a larger oil gallery.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
It could be my technique but everything I've ever JB welded has given out in about 3 months time. Best to buy a new one like SpeedRacer said.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
JB weld is not for the inside of engines
just my 2 cents
efrain240sx
Car: 1992 nissan 240sx HB
Just go to the junkyard and pay $2 to get in, walk around and every time you see a G20 or a sentra with a sr take it off. then just put them in you're pocket and go home that way you get like 3 or 4 of them for only $2.
drftsx
Car: 90 240sx(sr)
so a g20 and a sentra se-r should have the same timing chain tensor?? does the valve covers look alike?? wanna make sure.
efrain240sx
Yup valve covers look the same, but on the G20 on the valve cover it says infinity instead of Nissan and the Sentra one looks the same as ares but side ways. And a tensioner out of either engine works for the rwd sr20. I'm using one of a G20 SR
drftsx
Car: 90 240sx(sr)
alright thanks
