Ahhhh! Float... do not do this unless there is no chance that you have a clutch diff. Most likely the above guy happened to have a clutch type as well in his swap and didnt know it, added the synthetic, and made the plates slippery enough not to clunk. This will also affect the locking capability. If you have a kaaz diff, you must use kaaz fluid or a similar type of clutch diff fluid.ozzie! wrote:from nissanoffroad.net.....
A little over a year ago, I was getting a mysterious clunk out of the LSD in the rear diff when taking off from a dead stop. Before making the leap of replacing the LSD under warrenty, I had the Nissan dealer replace the OEM diff fluid (both front and rear) with Amsoil synthetic gear lubricant. The clunk immediately became less severe and after a couple thousand miles, disappeared completely. LSD function seems just fine as well.
Dunno if this experience translates very well to your situation but there it is for sure! hehehe...
Hootowl......
so maybe try the Amisol synthetic? might help lessen/remove the clunk noise?
too bad you cant be sure, depending on brand/age, etc., so your auction would be accurate, that way people would probably pay more and youd make quite a profitfloat_6969 wrote:I'm not going to touch it. I'm gonna put the rear cover back on, put my old VLSD back in there and then remove the clutch LSD out of this diff and put it up on eBay.
I use the car for autocross only and I'd rather have a Helical, and this should just about pay for it!
You do realize that a clutch type is just about as good as a helical for autocross right? I do agree that you should find out more info about it, and clean it up alot before selling to make a higher profit.float_6969 wrote:I'm not going to touch it. I'm gonna put the rear cover back on, put my old VLSD back in there and then remove the clutch LSD out of this diff and put it up on eBay.
clutch lube?float_6969 wrote:Yea, I tried that already. There was NO WAY IN HELL I could get them to turn in different directions. That was actually the reason I opened it up because I was afraid it had been welded.
I think the reason I couldn't move it was because the guy I bought it from replaced the fluid before he sent it and I don't think he realized it was a clutch type (obviously or he wouldn't have sold it for that price) and didn't put any clutch lube in there.
yea and that means your clutches are slipping.naed240sx wrote:You can add friction modifiers to the fluid to make it less chattery.
