Help Identifying this Part
prelewd
Car: 1970 Datsun 240z, 1972 Datsun 240z, 1977 Datsun 280z, 1991 Infiniti Q45
I couldn't find the factory service manual for the pathfinder via google search, so if anyone can point that out, it'd help me a ton. What I was hoping is if someone can help me identify these parts in blue and red:
I'm experiencing an issue where the blue and brown wire in the red circle are getting HOT, as in burns your finger to the touch. I'm sorta worried about my truck burning down, so I'm hoping I can simply replace it. Has anyone else here experienced the same issue? Let me know if I'm missing any pertinent information.
Truck info:
1992 Nissan Pathfinder XE 4x4 V6 3.0
Thanks!
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
They are power distribution plugs. You likely wont find a replacement anywhere except the junk yard.
Im not sure if that is your problem though. If they are getting hot, then I would guess you have a short in your electrical system somewhere, or one of your accessories is drawing too much current. The excessive draw would be likely to overheat the wiring prior to it being fused.
Wiring diagrams would be helpful, but it seems that the Nicoclub factory service manual repository only goes back to 1994.
Good luck.
