EC93 wrote:Like I said the problem isn't telling my parents. They don't even live in the same city as me. I live on my own and my car is not theirs. The problem is I don't have the money to fix this, which is why I was wondering if there was any way to fix it without spending a ridiculously amount of money.
Low budget fixes:
Bumper - If it is popped out then put it back into place. Using the Service Manual (links at top of forum) you will find how to remove the section that has popped off. Popping it back on will make the appearance (minus the scratches/scrapes) look as it should. Bumpers are often clipped on in most places, and bolted on in a few, so in a minor impact the clipped portions pop out of place while the bolted portions remain in place.
Fender - If you are looking for an absolutely budget fix why not talk to a paintless dent removal person? While PDR does not do miracles, and by the name will not do any paint work, they may be able to get the fender straight again. At this point you can decide whether to paint it. You could attempt to straighten it yourself, but you may end up making it look worse (some people try and leave 38 hammer dents in the place of one big dent).
With a little elbow grease you should be able to get it looking straight again, at which point you can take it in for an estimate to paint before deciding what to do.
