^---- THANK YOU!DAEDALUS wrote:zerothread?id=21144
Are you guessing this because you saw a new FUEL FILTER, or did you actually remove the back seat, rear deck, and open up the gas tank?ito wrote:The other thing that I was suggested to check, was the Fuel Pump; this one tends to be new as well.
From what I saw, it was the exhaust header gasket leaking.You wouldn't drive it, but the bad thing is... that's the only car I got at the time, so I got no choice.Well, yeah, like I was mentioning the loss of power: It DOES seem quite slower as I accelerate from a stop 'till it picks up to 35~40mph; as I be doing this, it makes a puffing sound.Now, the other thing is, i.e. on the freeway, when I already be going at a certain-steady speed (so to say, 50mph) then I try to accelerate more... in THAT case, it feels no problem.maxnix wrote:How did you inspect the fuel pump?
Is the head gasket or the exhaust header gasket leaking? In either case, I wouldn't drive it until correctly diagnosed.
You are right, all I saw was the "new" fuel filter. I apparently got them mixed up. I'll go ahead and get to the gas tank this coming weekend, until that time will I get a chance to do so. Thanks for bringing that up.Now that we're talking more about the PUMP itself, IF it was the fuel PUMP that was going bad... then what's up with the exhaust gasket--- on the driver-side of the engine?>> What's the cause of all that shaking motion? Cause I'd say it is quite intense. So to say, when I get to the first stop light from my house after having the car parked; that's when it rattles the most, so much that you can see my knees shaking too.CherryPoppinQ45 wrote:
