help help need help on how to take inner tie rod out?
240SX805
Car: Black 1990 240sx HB
help help need help on how to take inner tie rod out? i cant seem to get the inner tie rod out it wont loosen any one have advise on how to take inner tie rod out? or pics on how to take it off,,,,,
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Been a while but I remember after removing that lock washer, I took it out with a big wrench.
240SX805
take it completly off case i bent the corners off and its impasable to take off
LayNLow240
Car: 92 240 coupe
I used some vice grips and a jack handle. It will come off, you just need some force behind you.
240SX805
i kept trying wont budge ,,,,
goldfish
Car: 2005 Dodge Neon SRT-4, 1995 240sx
240SX805 wrote:i kept trying wont budge ,,,,
You try any penetrating spray like PB blaster or some of that royal purple spray stuff? Threads might need some motivation to break free
240SX805
yep all night im gonna try again right now
vancouverbc
Car: 1991 240sx
let me know if this writeup is any good
zerothread?id=330774
vancouverbc
Car: 1991 240sx
vancouverbc
Car: 1991 240sx
or this
http://zilvia.net/f/tech-talk/....html
let me know what was the best advice
moulton712
Car: coupe, hatch, both s13s
he first link you posted shows the best procedure. the other two are just pick of the area.
about that lock washer... you can use a flathead screwdriver and pry up all 4 sides then use the wrench to get the inner tie rod out. before you disassemble your car, go to the hardware store and pick up some of the washers.
if using a beefier tierod, (like tein) then the lock washers are too small to work. in this case i spot welded mine on.
i have run tierods with out the lock washer and with out spot welding. i strongly suggest not.
changing tierods are not as hard as it seems, just make sure you go for an alignment
240SX805
used a monkey wrench and it finnaly came off thanks alot,,, i cant drive my car till monday ,, on monday i will get it allined,,
Coupe_love
Car: mitsubishi eclipse
for future reference... there is a tool for this.. you can rent them at most parts stores.. (go to o'reilly)http://www.nextag.com/Lisle-45...EA4CD
