HElp fuel pump doesnt turn on
llama_of_doom
Car: mr2 turbo, s13 240sx
I have a 91 240sx when I turn the key in the ignition I dont hear the fuel pump priming I changed the relay and fuse in the engine bay but still no dice. What can it be some suggestions plz?
NISTECH
Have some one turn the key to the on position while you simaltainously slap the bottm of the fuel tank or use a rubber malet to hit it. If the pump then comes on you have an open circuit in you fuel pump. You will need to replace it if so. If that does nothing you could still have a bad pump but volt meter tests will need to be done at the fuel pump feed connector at the tank.
srblacks131
Car: 240
check to see if you have power at the fuel pump connector in the back. Also check for ground. If you have both its probably the pump. They are quite easy to replace. Goodluck
llama_of_doom
srblacks131 wrote:check to see if you have power at the fuel pump connector in the back. Also check for ground. If you have both its probably the pump. They are quite easy to replace. Goodluck
I dont think the fuel pump is bad because I just put this one its used so I suppose it is possible but I think its more likely its an electrical issue with the way my cars been acting. how can I see if the fuel pump connector is getting power? and how can I check the grounds? if I have to use a multimeter where am I sticking the prongs to get the reading?
srblacks131
Car: 240
OK. get a voltmeter and put it on dc volts. turn the ignition to on or run. Go to the back and disconnect the fuel pump connector. It on the passengers side in the hatch inderneith a cover. You cant miss is. Put the red lead on the white wire with purple strip. Put the black lead on any non painted ground. Should be battey power.
Im prettyh sure its the white/ppl but make sure with a FSM wiring diagram otherwise I can check at work tomorrow
vancouverbc
Car: 1991 240sx
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
if you are doing this alone you may get a false reading. turning th key on only runs the pump a few seconds. you will need to get a friend to crank the engine wihile you test for power.
