Ricardosaurusrex wrote:thanks for the insight. I have pulled off other transmissions however not one on a z. i would still like to know how to do it. i understand that going slow and steady will be key in dropping the trany your first time. ive read several other threads where ppl say its a simple job but with no guide for the removal.
with that in mind, is there any article you could point me towards that describes the automatic transmission removal process? i would really appreciate that support.
Thank you
Here's a somewhat how-to:
http://www.twinturbo.net/nissan/300zx/f ... ssion.html
The hardest parts of the job will be removing the bellhousing bolts and then getting the trans lined up correctly when you reinstall it. Some other tips:
1) drop the exhaust, either from the headers back or just the midpipes and H-pipe
2) remove the driveshaft (obviously)
3) drain the pan beforehand, IIRC there is no drain plug so just drop the whole pan
4) unbolt the torque converter from the flexplate, theres a little black shield between the engine/trans for access
5) you will need to either remove the cooling lines at the trans or at the radiator (if you do it at the radiator, I have no idea how you will get the trans out without messing them up)
6) remove the dipstick tube
7) you MAY be able to get the top 2 bellhousing bolts from the top (usually with the plenum off anyway), or use a 30-36" extension with one or more swivels on an impact gun from the back
8) don't forget to remove the shifter linkage from the trans, I honestly can't remember how but I think there's a linkage with some cotter pins
9) also don't forget to disconnect the electrical connections, there should be 2 or 3. I don't remember be able to get to mine so I remove the whole subharness with the trans (disconnect the other end from the alternator)
