WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sun Sep 16, 2007 3:48 pm
The first part is called the header, it connects to the engine. The part that connects directly to the header on the 240 is the catalytic converter. Then there is another thing that looks like a cat, however, it is hollow on the 240sx. Why you ask? Because Nissan designed it as gay as possible. This is actually nothing more then a resonator in reality. The BRM exhaust should connect to the aft side of the resonator where the two bolts are. You should NOT install the magnaflow CAT unless you have another header that eliminates the Nissan Cat that is attached to the stock header. Like the chrome one in the picture. If you have an aftermarket header, then you'll be able to use the new Cat.
So as things stand right now, you should have the stock header, the stock cat and the stock resonator installed on the car. If not, then do so. At that point you can install your BRM exhaust to the 2 bolts on the back side of the resonator.
I hope that made some sort of sense.
WD
