DAEDALUS wrote:Depends on where the headgasket fails. White smoke/sweet smell if the gasket fails between combustion chamber and coolant jacket, but it is entirely possible for it to fail elsewhere (into oil passage), allowing oil into the combustion chamber.
All the oil comunication between the head and the block takes place outside of the water jacket. However the head water jacket has slots making dashed circles, while the block has full circles for a water jacket.
Oil enters the head under pressure through a single point in mid head, and exits down the bolt holes.
It's possible for a blown head gasket to allow oil directly into the chamber, but I would put my money on the valve seals (13 year old rubber?) or if a history of poor oil changes, the rings.
