Before going into my brake bleeding problem i must admit that I did something really stupid... (
zerothread?id=159955) I opened each calipers i mean OPEN split apart the caliper's 4 bolt and found out later that I was not supposed to touch it...
Now i installed the 300zx caliper and the 300zx master cylinder.. from ebay.. with the nipple conversion.. (
http://cgi.ebay.com/ebaymotors/300ZX-Z3 ... 9599QQrdZ1)
My problem is that I cannot bleed it.. I keep on pumping the brakes and no fluid is comming out.. and the master brake cylinder reservoir is always full fluid will not go in.. the only thing you see. is very small bubbles inside the reservouir... ANY one know what is wrong??????????
