Help 97 Q45 SES code P1110
audiovisiony33
Car: 1997 Infiniti Q45
I had SES code P0325,P0330,P1110 triggered at one shot. I had replaced KS, clean TB, Plenum and cleared the memory. Car runs stronger than ever. Feels like I got my car swaped with someone else.
Driving around 10 to 30 miles SES light comes back on with P1110. I disconnect the battery to clear the memory and it's okay for another 10 to 30 mi. Can anybody help what's P1110 is and keep comming back on ? I don't feel any difference rather the light is on or off.
fourdrinie
Car: 2019 Q50
P1110 Intake Valve Timing Control, LH Bank
you will need FSM to diagnose and fix...you can download it free...look up previous posts on subject
fourdrinie
Car: 2019 Q50
FSM is available at http://www.phatg20.net has them, but the TSB are all at http://www.nissan-techinfo.com/infiniti/
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The part number is 23796-65F10-
You might read some of the threads with diagnosing this in the pathfinder forum. Info is in the sticky in the pathfinder forum, the pathy's have a very similar problem and you can use the same procedures to diagnose.
audiovisiony33
Thanks, elwesso
Is it easy to replace on Y33 ? where is it located ?I've tried to search on the forum. NIco web comes up done with blank page.Am I not doing the search right?
Now i know P0325 KS, P1110 VTC solenoid, what is P0330 ???
elwesso
2007 BMW M Coupe
P0330 is bank 2 KS, P0325 is bank 1 KS. bank1=drivers side...
ive never heard of an VTC solenoid going bad on a Y33..
In the FSM go to EC-338 and you can start diagnosis there. You can test everything you need to with a basic OBDII scanner.
audiovisiony33
elwesso wrote:P0330 is bank 2 KS, P0325 is bank 1 KS. bank1=drivers side...
Hey elwesso I need your opinion on this. Is SES P1110 different on Y33 than other nissan vehicles ? You said it's VCT solenoid and never heard of VCT going bad on Y33. According to my friend at infiniti dealer said code poped up as "Mfr controlled fuel & air meatering". Can you re-check for me?
I just don't get it! sounds like an air flow meter but car drives fine this is my second AFM. I had it replaced @94K. SES came on while I was on the freeway and after I shut it off at the dealer I could not restart the car back up and TCS/ABS light came on too so I had to replace AFM and relay pack.
It's funny when SES come on it can't be just one code. It have to relay into multicode. I guess that's how they were designed to make more money if one thing goes wrong. Thanks
elwesso
2007 BMW M Coupe
OBDII codes are the same regardless..... This is what I use for OBD codes...
zerothread/174934
I checked both in that thread and in the y33 FSM and it came with the same thing... I too have never heard of the VTC solenoids going bad on a Y33.
