Nissan Pathfinder / Infiniti QX4 How To'sNissan Pathfinder/Infiniti QX4 FAQ
CONTENTS
1. Purpose
2. Common problem areas
3. Trouble codes (common codes on the pathfinders are highlighted)
4. Solutions
5. WD21 Specific
Purpose: I am not a pathfinder mechanic or anything like that, the purpose of this FAQ is to provide the members with a decent overview on common problems. What I have done to compile this list is to simply search the Nissan Online Mechanic and Pathfinder/QX4 forum to come up with solutions to certain problems. ALSO, FEEL FREE TO REPLY TO THIS THREAD WITH SUGGESTIONS AS YOU SEE FIT!
• Intake Cam sensors
• Rear o2 sensors
• P017`1- Air Flow Meter.
• Turbine Revolution Sensor
• HVAC Blower Motor Problems.
Trouble Codes: These are a list of all OBDII codes. The ones placed in bold are codes that are commonly seen on Pathfinders and QX’s
P0000 No Self Diagnostic Failure Indicated
P0100 MAF Sensor
P0105 Absolute Pressure Sensor
P0110 IAT Sensor
P0115 ECT Sensor
P0120 TP Sensor
P0125 ECT Sensor
P0130 Closed Loop, Bank 1 Or Front O2S, Bank 1
P0131 Front O2 Sensor, Bank 1 Lean Shift Monitoring
P0132 Front O2 Sensor, Bank 1 Rich Shift Monitoring
P0133 Front O2 Sensor, Bank 1 Response Monitoring
P0134 Front O2 Sensor, Bank 1 High Voltage
P0135 Front HO2S Heater, Bank 1
P0136 Rear O2S, Bank 1
P0137 Rear O2S, Bank 1 Minimum Voltage Monitoring
P0138 Rear O2S, Bank 1 Maximum Voltage Monitoring
P0139 Rear O2S, Bank 1 Response Monitoring
P0140 Rear O2S, Bank 1 High Voltage
P0141 Rear H02S Heater, Bank 1
P0150 Closed Loop, Bank 2 Or Front O2S, Bank 2
P0151 Front O2 Sensor, Bank 2 Lean Shift Monitoring
P0152 Front O2 Sensor, Bank 2 Rich Shift Monitoring
P0153 Front O2 Sensor, Bank 2 Response Monitoring
P0154 Front O2 Sensor, Bank 2 High Voltage
P0155 Front HO2S Heater, Bank 2
P0156 Rear H02S Sensor, LH Bank
P0158 Rear O2 sensor, LH
P0159 Rear O2 sensor, RH
P0160 Rear O2S, Bank 2
P0161 Rear H02S Heater, LH Bank Or Bank 2
P0171 Fuel System Lean, Bank 1
P0172 Fuel System Rich, Bank 1
P0174 Fuel System Lean, Bank 2
P0175 Fuel System Rich, Bank 2
P0180 Tank Fuel Temp Sensor
P0300 Random Misfire
P0301-P0308 Misfire, Cylinder No. 1–8
P0325 Knock Sensor, Bank 1
P0330 Knock Sensor, Bank 2
P0335 CKP Sensor (Pos)
P0340 CMP
P0400 EGR System
P0402 EGRC/BPT Valve
P0403 EGR Volume Control Valve Circuit
P0420 TW Catalyst System, Bank 1
P0430 TW Catalyst System, Bank 2
P0440 EVAP Small Leak
P0443 Purge Control/V & S/V
P0446 Vent Control Valve
P0450 EVAP Pressure Sensor
P0500 Vehicle Speed Sensor
P0505 IACV/AAC Valve
P0510 Closed TP Sensor
P0600 A/T Comm Line
P0605 ECM/ECU
P0705 PNP Or Inhibitor Switch
P0710 ATF Temp Sensor
P0720 VSS A/T
P0725 Engine Speed Signal
P0731 A/T 1ST Signal
P0732 A/T 2ND Signal
P0733 A/T 3RD Signal
P0734 A/T 4TH Signal Or TCC
P0740 TCC SV Solenoid
P0744 A/T TCC Signal
P0745 Line Pressure S/V
P0750 Shift Solenoid/V A
P0755 Shift Solenoid/V B
P1105 MAP/BARO Switch SOL/V
P1110 Intake Valve Timing Control, LH Bank
P1120 TP Sensor 2
P1125 Tandem TP Sensor
P1130 Swirl Control Valve Control Solenoid Valve
P1135 Intake Valve Timing Control, RH Bank 2
P1140 Intake Valve Timing Control Position Sensor, LH Bank 1
P1145 Intake Valve Timing Control Position Sensor, RH Bank 2
P1148 Closed Loop, Bank 1
P1165 Swirl Control Valve Control Vacuum Check Switch
P1168 Closed Loop, Bank 2
P1210 Traction Control Signal Circuit
P1220 FPCM
P1320 Ignition Signal, Primary
P1335 CKP Sensor (Ref)
P1336 CKP Sensor (POS) Cog
P1400 EGRC Solenoid/V
P1401 EGR Temp Sensor
P1402 EGR System
P1440 EVAP Small Leak
P1441 VC/V Bypass/V
P1443 Canister Control Vacuum Check Switch
P1444 Purge Volume Control/V
P1445 Purge Volume Control/V
P1446 Vent Control Valve
P1447 EVAP Purge Flow
P1448 Vent Control Valve
P1490 VC/V Bypass/V
P1491 VC Cut/V Bypass/V
P1492 Purge Control/V S/V
P1493 Purge Control/V & S/V
P1605 A/T Diag Comm Line
P1705 TP Sensor A/T
P1706 PNP Switch
P1760 Overrun Clutch S/V
P1900 Cooling Fan
Solutions:
Intake Timing Sensors: First, read this thread. http://forums.nicoclub.com/zerothread/116383 . NISTECH, our resident Nissan technician, has listed ways to help clearly diagnose and correct this problem.
Rear O2 sensors: http://forums.nicoclub.com/zerothread/114207. This thread is also very helpful. The gist of this is that the rear o2 sensors commonly fail, and not only do they need replaced, but there is an ECM reflash needed to correct the problem permanently.
P0171: http://forums.nicoclub.com/zerothread/135082. What this thread deals with is a lean condition on one or possibly both banks. What this generally is caused by is the MAF (Mass Air Flow Sensor) going bad. Some mechanics will say that a bad MAF will cause it to read lean on both banks, but this is not always the case. You can read the readings on both banks and often you will find that the other bank is reading lean, but not lean enough to throw a code. New MAF from the dealer or NICO sponsors are around $400, but many people have had good luck with replacing them with used MAFs from wrecked cars.
Turbine Sensor- Often this sensor does not fail, but instead leaks fluid, possibly on other components. Sometimes its been known for the fluid leakage to cause other sensors, such as the o2 sensors and such to fail as well.
HVAC Blower Motor- Sometimes the blower motor will operate only on one speed (usually high) or it will not operate at all. Generally the blower amplifier is the culprit.
5. WD21 info for Pathfinder from 87-95: Main problems.
Frame rust. Even on non-offroaded Pathys, the frame can rust out quite badly from the inside out, particularly in the rear over the wheels and above the gas tank. Tap on your frame with a small hammer or poke it with a screwdriver to see if you have more holes than you should. ALWAYS inspect any WD21 Pathfinder you wish to purchase before buying it in this regard. Other rust-prone areas are directly under the gas pedal on the floor (the catalytic converter is there and sometimes a leak can shoot superhot exhaust at the floor, which rusts it out badly), under the back seats on the floor (poor seam sealing on Nissan's part) and at the tension rod frame mounts up front. Tension rods are the short bars that go between the lower control arm and the frame in the front suspension. The tension rod mounts have a tendency to waller out and/or rust out, which can result in a broken tension rod and the need to re-weld some steel back into the mounts to fix the problem. Tension rods are also called compression rods or strut rods. I recommend using polyurethane bushings to replace stock rubber tension rod bushings whenever possible.
The stock transmission cooler for automatic transmissions needs replacement! On automatic transmission-equipped Pathfinders: failure of planetary gear set and loss of reverse or forward gears: the stock transmission cooler on WD21's is a far cry from adequate. The stock cooler clogs up over time and chokes line pressure to the transmission, which overheats it, reduces lubrication and RUINS the transmission. The stock cooler is located inside the radiator, which has line inlets at the bottom of the rad.
If you are reading this, have an auto 87-95 Pathy and haven't done so yet, GET AN EXTERNAL TRANSMISSION COOLER.
DO NOT USE the stock transmission cooler. Get yourself the largest trans cooler you can find and install that instead. The plate-type coolers work better than the tube-and-fin type. I personally have a pair of 8x11 plate-type trans coolers from junkyard Ford Exploders installed on mine and have had no problems with them to date. They cost me $5 each and took about an hour or so to install in front of the radiator along with some hose clamps, some hose and a neat ziptie-like mounting kit I bought at a local auto parts store for $5. This will prevent the overheating and eventual internal destruction of your transmission.
SHIFT_it yourself
1994 Q45t- 5 Speed
NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328
