this site didnt notify me of someone responding to my post so i will keep checking back
For this, next time you post a reply, just click the
FULL EDITOR button beside the
SUBMIT button at the bottom of the text box. Then check the box that says,
"Notify me when a reply is posted" under the options list. Let me know if that's available
I hope this helps you out to help me out and thanks for your quick response
You bet! And it sure does help me get somewhere. Thanks for the follow up.
This is my opinion:
If you have the diagnostic report, post it here, or let us know what diagnostic codes the mechanic found. I am not saying that the engine isn't toast, it's just that we currently have no data points to know what your and the OP's issues certainly mean. To me, the symptoms point to a camshaft/crankshaft issue (except the peculiar slipping of the rear you mentioned; but that might just be cutting power and regaining it as the sensor goes in and out)
If you don't think you will not be getting to it for the next 6-8 weeks anyway, I would take some time to try some cheap-but-not-bad fixes. First, ensure the oil level is in the correct range and replace the camshaft sensor using
this guide if you wish.
The cost of a sensor will probably be cheaper than towing it back and forth to Infiniti and paying for the diagnosis, although I would recommend an OEM one for this issue. Still, hold off on spending any more money until you get the results of the diagnosis that you paid for.
On the other hand, you might be less interested in the guesswork and diagnosis and would rather get it over with. In that case, I would just take it to Infiniti as you proposed.
Also, I know you mentioned hitting a wall at 65 mph, any chance you kept an eye on the RPMs to know if it is the engine rather than vehicle speed that is being limited?
