hellow
diederikdemot
Car: nissan z32 300zx tt swb
hellow i'm a technical car nut
work as technician for belgian company that sells and services hyster trucks
i have mild track/touring 300zx z32
hobby's are race cars and going to race"s , ski , a good film and as i'm from belgium good beer .
diederikdemot
speclist if you are intrested
Motor/koeling
Eagle connecting rods
Greddy 89mm forged pistons
JWT 400+ cams with heavy duty valve and VTC
springs
Fidanza flywheel
Greddy extreme timingbelt
ARC M105 SMIC
Greddy steel headgaskets
Twin AFM
DTA Intake hard pipe kit
KOYO radiator
New original oilcooler
HKS GT2530 BB turbo's, new centres
HKS SQQV BOV's
Underdrive pulley
New oil pump 13000km
Greddy oil sandwich adapter
Twin Apexera intakefilters
PFR6B-11B Spark plugs
New enigine mounts
CZP polished radiator guide
New thermostat(13000km)
EGR bypass kit 300 degree
Cooling hardpipe kit lower upper pipe
BDE performance camshaft pullies
Engine balanced up to 10000rpm
555CC INJECTORS NEW STYLE
Motor/elektrisch
Defi BF meters: 2 EGT, 1 boostDefi display: oiltemp, oilpressure, watertemp, fuelpressure
Apex AFCKenne Bell Boost a pump
New wiring harness
DTA High performance ECU upgrade chip
Greddy profec B spec 2 boostcontroller
Greddy turbo timer
ADAPTRONIC SELECT ECU
map sensor
iat sensor
wideband sensor
Aandrijflijn
Z1 1pce driveshaft
JWT Clutch
Stainless steel braided clutch line
Stillen short shifter
Forged pivot ball
Uitlaat
Testpipes 70mm
100mm mufflers
2 extra silencers anti drone
Uiterlijk
J-spec rear lights
J-spec front bumper
No rear spoiler
Stillen type 3 side skirts and door fillers
Kosei 10 spoke 18" wheels(235 265 Bridgestones)
HID Xenon lights
Clear side repeaters
fog light delete , air ducts
Interieur
Stillen centre console
Sparco steeringwheel
Sparco 50mm spacer
Daikei Boss kit
DTA Speedometer rings
Z original floormats
Ophanging
KONI shocks
Eibach springs
Powertrix adjustable control arms front
Powertrix adjustable control arms rear
Stillen swaybars
HICAS lock out bar
Remmen
Porsche 997/ Brembo front brakes, 330x32 drilled rotors
Goodrich stainless steel brake lines front+rear
DTA Brake brace
Brembo high performance rotors drilled rear
Axxis ultimate brake pads rear
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO! This may help you with posting pictures.
How-to Upload Images Using Imgur
How to post pictures using photobucket
1) Log into your photobucket account.
2) Click on one recently uploaded picture. (You MUST post them INDIVIDUALLY.)
3) On the right side of the screen you'll see SHARE LINKS (see image below).
4) Left click on the box next to IMG. You'll see a confirmation that it copied the link.
5) Paste as a reply in this thread. It's already formatted with the correct tags.
6) Click the submit button.
Welcome aboard, Diederik! It's good to meet more Z32 owners from across the pond!
NolimitZ32
Welcome aboard! That's a great setup you have, very similar to mine, lots of fun.
diederikdemot
diederikdemot
diederikdemot
diederikdemot
shawnm565
I like the car!
rgregoryb
Car: 1992 300ZX 2+2 NA
Nice Z
Beautiful!
