Hello people of Nico, I am the new guy.
LS6HLS30
Howdy. Signed up to the forums to do some research and maybe gain some more technical knowledge. I have a 72 240z with an LS6 and TH400, and I am trying to figure out if anyone makes (OEM or Aftermarket) a R&P gear set below 3.54 for the Q45 LSD R200 diff. With the TH400, stock Q45 diff gear set and a 24inch tall tire I am in the low 3000rpms while at 65mph. That needs to change, for the sake of my wallet and my hearing. I can get a bigger tire under the car but it wouldnt be enough to get me into the rpm range Id like to see. I am trying to crunch some numbers and figure out if a new transmission/drive line or R&P gear set would be more cost effective. Any suggestions?
alphapig
Car: Nissan Altima Coupe S 2.5
My only suggestion is to post pictures of said LS swapped Z :bigthumb:
Also, make a post in the classic Z forum
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Welcome!
http://www.grimmjeeper.com/gears.html
Great calculator for trans/diff/tire ratios. Since it's meant for 4x4s you'll need to plug 1:1 in for the transfer case and then you'll be set. It'll give you vehicle speed in a given gear with your selected rear end ratio so it should help figure out what to shoot for. Even accounts for tire size.
LS6HLS30
Holy sweet baby Jesus, that site does all the math for me. :cheers:
addicted4life
Car: RHD '93 Fairlady 2+2, 3076s, Haltech, & Hoosiers. Go baby, go.
Welcome!
jdansmith
Car: 2008 Sentra 2.0S, 91 Sentra 1.6DHOC, 89 Hardbody Z24
Welcome aboard!
windbooster
Car: Nissan 370z
hello, nico and new friends. :naughty:
float_6969
Welcome to NICO!
Although I have to laugh at your complaining about 3K @ 65mph, LOL. I WISH I could get my motor that low, but the little 1.8L turbo in my S14 becomes a useless hunk of metal below 3K, LOL. Good luck with the R&P set. Nissan used A LOT of different gear sets in stock cars and most of the time what you want can be found from another vehicle.
M35-Brad
Car: 2009 M35 Sport
LS6 in a 240z...holy smokes. That thing has to scary fast! Working on a S30 280z as a side project...always loved those cars.
PapaSmurf2k3
Site Admin
Welcome to NICO!
I thought the 300zx TT got a low gear set, although I can't remember what the ratio was.
Edit, google is showing 3.692. Nevermind :(
float_6969
I think he's gonna have to find something out of a truck or a pathfinders.
Welcome aboard!
Float, I think he means "low" as in numerically. I vaguely remember a 3.35:1 ratio diff in one of the R200 cars, but I could be wrong.
Aha, found it: the-ultimate-final-drive-gear-ratio-thread-t228683.html
Combining the 3.35 ratio with a slightly taller tire should get you substantially closer to your goal.
nissangirl74
Welcome to NICO! :wavey: Pics of the Z?
float_6969
AZhitman wrote:Welcome aboard!
Bah, I always get that backwards.
hannibal
Car: Red Line to Glenmont
The Z32TT is an R230 diff.
And I woulda lost this bet. I thought the Q's 3.54 was the lowest diff gear...
LS6HLS30
float_6969 wrote:Welcome to NICO!
I bet your 1.8l gets outstanding MPG next to my 5.7l :chuckle:
Looks like the 350z that had an AT came with a 3.35, but the diff is labeled as a R200V (Along with the Q45 diff)? People over at the Hybridz forum seem to label the Q45 diff as R230. Are the two differentials the same?
The early (90-96) Q had the R200V. They're probably referring (R230) to the later Q diff, which you don't want anyway.
I'd check part numbers and dimensions for the R&P for a slushbox Z33 and compare them with what you currently have. I'm pretty certain they'll play nice together.
Alternatively, snag a Z33 diff from a junkyard (they're plentiful) and crack it open!
LS6HLS30
Might have to come to these AZ junkyards where Z33's grow on trees ;)
Ill go harass the local Nissan Dealership's parts counter guy and see what I come up with.
float_6969
LS6HLS30 wrote:I bet your 1.8l gets outstanding MPG next to my 5.7l :chuckle:
I doubt it. I'm on E85 and my mileage is in the upper teens. I'm HOPING that some creative tuning will let me break into the low 20's. But when it was still on pump gas, I did get 35mph out of it if I kept my foot out of the loud pedal, LOL.
LS6HLS30
13-15mpg if i keep my foot out of it. :/
nissangirl74
LS6HLS30 wrote:13-15mpg if i keep my foot out of it. :/
My Frontier only gets 2 mpg better than that, if I keep my foot out of it. :(
PapaSmurf2k3
Site Admin
I get about 26-27 in the Miata when I completely beat the s*** out of it... although I do have a decent "cruise" tune. But yeah, when accelerating, hold on. 1.8 liters baby! I've gotten 36 during low speed (55 mph) cruising.
LS6HLS30- how well does your car hook? Can you make good use of your power? I'd love to see a video.
What are your air/fuel ratios?
LS6HLS30 wrote:Might have to come to these AZ junkyards where Z33's grow on trees ;)
www.car-part.com - Give that a whirl, brotha!
LS6HLS30
PapaSmurf2k3 wrote:I get about 26-27 in the Miata when I completely beat the s*** out of it... although I do have a decent "cruise" tune. But yeah, when accelerating, hold on. 1.8 liters baby! I've gotten 36 during low speed (55 mph) cruising.
The car hooks very well. I have hardly any wheel spin, I run ET Streets and I like them more than my M/T slicks. My A/F cruising is in the 14s and 15s, WOT is in the 11's.
frapjap
'07 Subaru Legacy
You need more gears :couch
Any reason you didn't go with a T56?
hannibal
The Q's R200 diff is often mislabeled as an R230. But it does in fact use a 200mm ring. IMO the source of confusion stems from the Q using bigger axles like the Z32TT so people assumed the diff was larger.
